bower100
I'm working diligently on my "new" bike and the questions as I go are piling up. So, I'd like to ask about these things befoe I get bogged down with doubt.
By USA model I guess I'm saying, I have no ignition key, smog stuff, coolant temp.sensor in the back if my cylinder.
1) The black plastic neutral switch below the C.S. sprocket..... I guess it's sole porpose is to illuminate a neutal light on the stock instrument guage?
2)What is the little brass nipple next to the intake manifold .... screws into the cylinder... for ? A vacuum test port? Or does a hose from somewhere plug on there? (I was gonna remove and plug it).
3) What's is that black rubber cylendrical shaped electrical thing, under the gastank, behind the ignition coil? Parts list calls it a 'condenser".
4) And how about the flat 2" square aluminum "box" with 4 wires out of it,... mounted on the right side of the steering head? Maybe the flasher?
Last.... does anyone make a nice compact multi-function switch housing for the handlebars. Switchhousing for t/signals, horn, headlight on/hi/lo / Thanks, Dave
