Joliet;13891 said:9.48mm
Coffee;13893 said:Many red/blue/other dealers carry those shims, but last I checked the kits from Motosportz were quite affordable compared to local shops.
ghte;89442 said:I believe they are 99% identical and in the head/valve area they are the same
dirt_rider93561;122806 said:Are the 09 bikes the same size as these earlier bikes?
dirt_rider93561;122822 said:I was wondering if the valve shim diameters are the same or if they changed them between the years. I see that the 06 and 07 TE450 uses a 9.48 mm OD shim and I wanted to know if the 09 TE450/510 uses the same size OD diameter shim.
dirt_rider93561;123025 said:That's a bummer. I only have a 7.48 mm shim kit, guess I will have to get the 9.48mm kit as well. Thanks for the replies.
