2007 starting issues continue
Bartz
So I had cold and hot start issues. Fiddled with carby with no luck so took it to a professional to undo my handywork. He took it back to where it was, think it was only in need of mixture adjustment.
So cold start not too bad now, needs a tiny bit of throttle though which is against Husky instructions.
BUT hot starts are IMPOSSIBLE! It cranks and nearly starts but then pops and stops then in no time the electric starter drains (new battery in place). Tried the kickstart but it's impossible too. I leave it off to give battery a rest and for a while it'll recover charge but still no start. Then sometimes during all this with very little starter action it'll start up quick (rare)
I'm losing my cool with it very quickly, can anyone save me from getting over dirt bikes before I've even begun?
I'll be in the shop again monday with instructions to fix or I'm over it!
HELP!!!
I always start from the beginning. 1. Check compression, 2. Check valve clearance (when bike gets hot valves tighten up
And can cause hot start issue)3. While you are checking valve clearance, make sure valve timing is correct
3.Do the carb like your life depends on it(perfect) 4. Make sure intake boot, tank, tank venting is all perfect.
5. It's never timing (so make sure you check it)6.get a spare plug, and when you get it hot as soon as it won't start,
Pull boot off and see if you are loosing spark. All this can be done in an hour or so once your set up and ready.
I usually start here with bikes acting goofy, then go to leak down etc....
Good luck, let us know..
Thanks James, I'm not experienced with these things, want to learn but not sure I'm up to it.
I had the valves replaced at a major service just after I bought it. I guess they'd check compression then? How do I do this, seems to have heaps as often have to decompress to kick or electric start (is this the same compression?)
I'll let the knowledgeable ones have one more look and report my progress....
