125-200cc 2007 Husqvarna Wr 125 No Lights Working
No lights working
  • lights
    Votes: 0 0.0%
  • elektrical
    Votes: 0 0.0%
  • Total voters
    0
IsacH
IMG_0622.JPGHello! I have a 2007 Husqvarna WR 125 and i have no lights working. Can anyone post a picture of the cables behind the light is connected too?
Power wire should come out of the regulator, go to the switch, then split to both head and tail light. Ground wire should go to both light grounds and also to spot on bare metal, or ground to a bolt that goes into the frame. I didn't have lights on my 2013, but that is how I wired mine when I added lights to it. You can make sure that power is coming out of the regulator with a test light or meter, then if that is good, check all the wiring and the bulbs, and current coming out of the switch.
