2006 TE610 Piston replacement question
RayRay
The stock piston has two compression rings. The Wossner I bought has only one. Is this correct? Seems like an inferior design compared to stock or possibly sent the incorrect piston?
I still have my original piston, but I remember people who, back then, discussed about pistons having one compression ring to increase performance thanks to less drag and also high compression pistons and Wossner was one of the manufacturers they discussed about.
IMO it's not necessarily an incorrect part.
I have the same Wossner piston as it's the only one you can get easily. HTC sells a single ring piston also.
