cjoecruz003
I checked the clicks on the cam chain tensioner and it was fully reset to 0 clicks showing.
Thinking it was a fluke, i installed it and ran the motor for a few mins throught the rpm range and it Ran great, then pulled it back out to check.
Don't have a pic but the grooves/teeth/clicks were worn down on the first 5-6 causing the ratcheting mechanism not to catch on them. So as the motor spun the cam chain tensioner was being pushed back in to 0. So I replaced the tensioner.
So w the new tensioner in, I've done one track day and only put about 20 miles on it. Noticed today an oil leak after I started it. The tensioner itself was cracked clean through. Seems the tensioner is being pushed backwards when the motors running but what would cause this?
Are the RR tensioners stronger as a unit or is the spring just stronger?
I'm going to get a new tensioner and if it breaks again then I might replace both chain sliders and the cam chain. Timing is spot on when I've checked the valves and again the bike idles and runs the RPMs just fine so I'm kinda lost.
