2004 TE250 Starting Problems
tigers9472
I recently bought my TE250 right before winter so didn't get to ride it much but in the fall after I bought it, I tried to start it a few times and its very difficult. Has electric start only. Right after I bought it the prior owner had the idle set pretty high, but it seemed to start ok after three twists of the throttle. I adjusted the idle and now I can't get it to start, and can't find the prior point of the idle where it did start. I have to shoot just a bit of starting fluid in the intake to get it started, which I know isn't good and I hate doing and once it is getting started it backfires a little bit. It is getting spark, and actually once it's started and warm, will usually start right back up again. The prior owner said he never had any problems so did I just mess up the settings with the idle screw? I can't even find the air screw on the carb as I read I may need to richen the mixture. Any ideas would be appreciated. Thanks!
The idle/pilot jet is caked with varnish, making it a much smaller jet (if not completely clogged). Remove the idle jet and clean it by getting a very small strand of copper wire, like you'd find in old speaker wire, twist a 2 foot section around your finger to make a spring-like shape, and then pass that thru the jet a couple of times, looking thru the jet at a light before and after the passes, to see if it's getting bigger. If the varnish cannot be removed like that, you'll need to buy a new idle jet.
