2004 te 450 throttle stick
Kyle Blackburn
I laid the bike down unexpectedly . but now that I have fixed what I brokeand started riding again the throttle no longer snaps back to normal . what could it be and how can I fix it .my bike also has a mikuni carb with a throttle body .
a mate had this happen to him on an (08 i think) 450 (throttle sticking)
cables were being crushed together where they were routed between the tank and frame.
doesn't take long to get the tank off to have a look
The throttle tube is closed over the end of the handlebar, and when that closed-end tube gets jammed against the handlebar, the throttle will not spring back. When this happened to me, I took the throttle tube off and cut the entire end out of the tube, so that when I fell over and the handguard jammed into the handlebar, the throttle tube was no longer involved. I also used a large fender washer to kinda keep dirt from getting shoved into the open end of the throttle tube.
