2003 TE 610 swing arm swap
huskyjv
I have a 2003 TE610E and wanted to know of anyone has swaped out the rear swing arm for a 2008 610 rear arm. I purchased a set of Baer supermoto wheels front and rear off a guy that had a 2008 610. He said they would fit my year and that was not true. The axles are a different size front and back. I made custom adapter spacers for the front wheel and modified the caliper bracket to fit the big supermoto rotor. The rear is more involved as the 2003 swing arm seems a bit to narrow to fit a big street tire/rim. I will have to make spacers but will also need to cut the caliper mount and adapt it to the top side of the swing arm to clear the big rear tire. I will also have to space the rear sprocket out to clear the tire sidewall. My question is instead of reinventing the wheel is it possible to swap a 2003 swingarm for a 2008 and just bolt on my wheel and caliper set up? Any advise is really appretiated!
