BenM
		I've got a 2000 WR360, but just recently swapped in a 2000 WR250. The 360 motor has a slight crack on the top of the clutch side case right where the kickstart shaft runs (not related to the carb hitting it), but the Mikuni TM always seemed to rub/hit on the top of the case.
Have the same issue after swapping in the 250 engine with a TMX carb. It seems like the airbox boot is forcing it into the top of the case very slightly, almost exactly like the 360 motor. Without the airbox boot connected the carb sits perfect on the intake manifold, but airbox boot isn't lined up properly. It's hell getting the airbox boot connected with the floatbowl rubbing the top of the case. I even removed the airbox from the subframe to get it to fit better and it didn't do much.
The shock is straight, subframe is straight, frame is fine and the airbox is good. The airbox boot is used for bunch of years, so maybe I can try getting another one, but I'm at a loss for what to check next.
Anyone else ever deal with this issue?
