2 bikes, 2 puddles
MrClean
Found small puddles of fork oil under both of my bikes yesterday. My 2011 SM630 has 4000 miles and my 09 TE310 has 3000. It seems odd that both bikes developed fork seal problems at the same time. Could it be the 100 + degree bone-dry weather or, do you think its just a coincidence? Is it normal to already need new seals on these bikes?
Do you ever vent the forks? If you've got higher-than-normal temps they could build pressure and be more prone to leak...
I probably don't vent them often enough.
This time I heard a little air escape from the 630's fork when I vented it. I'm hoping that will take care of the problem. I'll go for a short ride this evening and check it when I get back.
The 310 is definitely getting a new seal...
Have you tried the trick with the feeler gauge? Take the smallest one and clean out the dust seals.
Thanks for all the replies. The feeler gauge worked like magic! No more leak! You guys saved me time, agony, and money. Thanks again!
