125-200cc 1998 CR125 reeds or reed block options???
johnhuskywaine
After having the reed block of on the new project, I need to replace reeds or a aftermarket block replacement, any ideas will be a great help?
From what I can tell they are vforce 2 reeds? You're reed cage should have a number stamped inside of it. You can cross reference this number a honda cr125 may use the same reeds.
I know my 08 125 has the same reeds as a late honda 125
Thanks for reply,
I've ended up ordering 1 reed from USA of eBay there was no number on cage either?
At a later date I'll replace the whole unit for a aftermarket as replacement standerd reeds will cost just as much!
Plus I'm desperate to get it back together and into the woods ;)
