125-200cc 1993 360 wxc. upgrade help?
shane360
i just bought a 1993 husky 360 wxc. im looking to upgrade it a little. i was thinking putting a 38mm carb and an exhaust on it. i was also looking for plastics. where shold i get them? i want to make it a little more snappy. top speed and power is great! any other suggestions?
make the 360 more snappy? these bikes are known for being almost TOO snappy! is the motor in good health? compression, jetting? dc plastics has some stuff available..the pipes are pretty bad on these...i bought a dynoport high volume pipe i will be trying out once i have the motor back together. maybe check your gearing if someone has geared it taller..
Lectron 38mm. Don't worry about the pipe.
There is a how to on I think TT that wally put up about flowing the intake. Lectron + that + 14:48 gearing was great for me. Fun, but it'll wear you out with all the snap.
+1 with lectron and gearing.
Intake mod was easy but im ignorant
An didnt notice much difference.
Good bikes if you look after them.
If you dont lectron check the jetting mine was way
Too rich an as fowling plugs every 4 hours.
Stock jetting was huge!
Check exhaust packing just to be on safe sude, some oils do smoke
I use putoline mx5 an the smokes a little even with lectron.
Dont lean out your oil mix keep it a minimum of 50:1.
