1979 250CR/390CR Engine Swap
crew67lm
Is this as simple as taking out the 250 motor,and dropping in the 390? Would have to use the 390's pipe,ignition,carb,etc. Is there more to it than that? Thanks.
You will need to use the 390 pipe and the complete magneto for the 390 due to it used the larger diameter rotor and the stub shaft on the 390 is different compared to the 250's due to the larger rotor the 390 uses. You can use the same carb (38mm Mikuni) just re-jet it for the 390. Motor mounts are the same.
