1978 390 AMX clutch spring question
grouty
Auto Lover ...
I was stripping and checking the mainshaft on my 390 AMX tonight. The clutch springs fitted for 2nd, 3rd, and 4th are different.
2nd gear has green springs
3rd gear has red springs
4th gear has red springs.
I know they are different rates, but my question is ... are they suitable for enduro going ?
Is this the usual set-up ?
On the down side, 2nd and 3rd gear shoes are wasted :(
4th gear shoes cleaned up very nice with the hacksaw blade and are good to go.
The Teflon coated bushes seem good too.
Hi Grouty,
The red springs are part # 161255401 and are rated at 12 pounds
The green springs are part #161255402 and rated at 8 pounds
second and third gears standard springs are red 12lbs
Fourth gear standard spring is green 8lbs
Optional springs were part # 161255301 rated at 17 pounds and this one was plain no paint color. Also another optional spring was part # 161260201 and rated at 22.5 pounds and painted white.
For enduro riding I would run 2nd red, 3rd red and 4th green. On the 420 autos Husky used the plain colored spring on 3rd gear allowing 2nd gear to rev out higher. Hope this helps
Marty
[/URL][/IMG]
Thanks Marty, I will swap the springs around this weekend.
Yes please Steve, if you don't mind. The ones fitted have worn down past the bottom of the grooves ! Even if I did re-cut them I think they would be too small.
