Gord
Just got back from a Vintage MX race. Before I start tearing things apart, I thought I'd ask for some advice or opinions. This is a 1973 WR250 with a CR250 Transmission.
Here's what's happening: Short story; Pull the clutch in, let the clutch out and the clutch arm on the motor won't return. The bike has always been a creeper when the clutch is pulled in and in first gear, on a starting gate. But today when I let out the clutch, the cable actually becomes so loose at the handlebar lever that the whole adjustment assembly comes out of the lever. I took up all the slack in the cable at the lever and all seems fine, until the bike is started. And again; pull it in, let it out and everything is loose again. With the clutch cable off the bike, I can move the clutch arm, on the motor freely about an inch and it won't go back by itself.
I'm not a Husky mechanic and don't pretend to be, so any help on where to start looking for the problem is appreciated. And if you need more information, please ask.
