woodsman09
1971 360C
Looking for help with the brake drum shaft which extends through the right side of swing arm, the axle slides in from the left and through this brake drum shaft. There is not enough room to remove the tire/rim assembly with this shaft still extending through the swing arm. I have tapped it with a hammer gently with the nut screwed onto the very end of the shaft but I am not sure if this is the right way of disassembling it.
Also, there are plates, approximately 1/8" thick welded to the back of the swing arm which prevents the removal of the entire wheel, is this factory?
