1971 400 cross
Etchandy
Hey guys, I just inherited a 1971 400 from my father. It’s been in the family since new. I have the owners manual and original California title..
The bike is currently in pieces but 100% accounted for. I plan to get it back together in running condition.
Everything is in good shape but wear and tear from riding. I originally considered doing a full frame restoration but am thinking it would be cooler to show to nicks and scrapes and scars of a life of riding (patina).
What do you think? What would you do?
Complete restoration, not just refurbished, is expensive and time consuming. So, rebuild the motor, suspension, ignition, and carburetor. Can't emphasize this enough. You can always make it look pretty later.
Important motor components to replace: bearings, seals, gaskets, clutch plates and discs, points & condenser, float bowl gasket slide cap o-ring. You can always replace the top end later, so what if it rattles a little for now. If your going to ride a lot or hard then consider chain and cables if needed.
