125-200cc 144 replacement piston kit etc
hawaii-rider
Where is the best source for the WR144 replacement piston/rings etc to do a top end.
My son just returned from Afgan and the legs are headed to LT Racing and the top end is a bit tired so time for a new slug and rings.
Thanx
HR
You should pull it apart and see if you really need a piston or just a new ring, as you probably know it is real simple. I do not have the piston kit but I would give you a new OEM 144 ring to say thanks for the service to him.
Yup, gonna pull the jug and check everything and obviously the PV cleaning etc (his bike was the Dirt Rider test bike)
Just wanting to see who carries the bits cause my internet search didnt really come up with anything on the 144 kit.
I will share your offer for the ring with him, Thank you! Im beyond happy he is home safe.
Now I just need the ring end gap so I can measure !
HR
Walt sometimes has a very lightly used 144 piston around from 165 builds. Might ping him. Other than that Bills.
Ideally the squish with the .8mm base gasket is ~.045" with a new gasket. The gaskets collapse with time and end up at ~.040" which is ideal. The ring gaps new are going to be between .011"-.012". Obviously that can vary slightly but not much.
This isn't exactly what you need, but I have a complete 144 top end (head, cylinder, power valves, piston, rings, etc.) it all looks brand new even though I put on a max of 10 hours total. I'd rather not sell the piston/rings separate from the rest though.
I had to use a .3 mm base gasket to get mine to 1 mm (.040") quench. Stock gasket was .5 mm.
Still have the 144 kit available?
After a full season of off road racing I am looking for a water leak. Went in after the base gasket and am just amazed at the top end,looks just like the new take off 125 top sitting in a box. Just going to add gaskets and keep going.
