Hi All,
I have found a gap where water and air get through between the two plates that provide the mount for the air temp sensor.
Inspecting further one side of the plate is not crimped. See pic below the right most nut has been crimped up so it's holding the two plates either side together (circled in green) but the left one (in red) has just been inserted and doesn't pull up against anything.
The parts manual only mentions the plate on top but nothing about being two. Is this a manufacture defect? Is suspect will need to replace that airbox section. Is someone able to check theirs on either an 13/14 TE250/310 and see if both nuts are crimped?
As it's not pulling tight it's creating a gap which water can get in.
Thanks,
Thanks,
