13/48 Gearing for TE310?
Rizzkid
Hello Guys,
Ready to make the stock 2012 TE310 ready for tight sandy trails here in NJ. Currently the bike has the stock 13/40 combo. I checked out many gearing combos using the website http://www.gearingcommander.com/ and seem to like the 13/48 combo as it seems to be a good trade off for trails and some roadwork. I ride a few miles on 50 mph hr roads on occassion and need better gearing down low on the trails. Anyone have this combo? How do I know how many links I need to buy for a new chain wit the 13/48 combo? Will the lower gearing also help with the efi jitters at low throttle settings? Or do I need a re-map.
I'm not sure how accurate that site is. I put in my 12/52 gearing and it says I will hit 82.3mph at 11700rpm. Actual speed at that rpm is a little less than 60mph. I found 13/50 wasn't low enough for the tight stuff I ride. I soon went 12/50, then 12/52, which is just right for real steep mountain single track. I can dead start on some pretty steep stuff. It just eats up logs and other nasty stuff too. If you can maintain momentum, 13/50 is definitely doable, but I am no superstar.
I was at the stock 13/50 with the power up kit. I switched to 13/47 to get a little more top end speed without having to wind out the motor as much in the open areas and on the road to keep up with the 450s and 500s I ride with. It didn't negatively affect the bike in the slow techincal stuff in 1st and 2nd gear. I'd say it's a good overall happy medium.
-bh
