Factory Squarna
Hi I'm struggling to find a good regulation of the powervalves, on my 07 wr 125....
If I set the pv arm bolt almost all the way up (hence preloading le little spring) , the bike has a great spread of torque, but then it falls really flat on the top end ... I suppose that the valves don't fully open!
Then if I put the bolt down, the powerband will be very poor, pathetic, until the big midrange hit and finally good top end. Because this way the valves will start from a more opened position, and wont seal tightly at low revs, although its the only way to make them fully open!
I cant seem to find a middle spot that makes the valves open fully, and yet retain a decent sealing of the valves at low revs.... The bolt is actually between 1/2 and 3/4 up....
Also I cant see the point in making sure of the piston to valves clearance, a very stressed point on this engine as I read, if then when you adjust the pv arm bolt down you actually move the valves up from the rest position and enlarge the clearance!
Please give me your thougths because I'm sick to have a bike that can run fine only at low revs, or only on the top end, why cant it just run well all the way down to top like a ktm 125....
Such a shame because the handling of this bike is wonderful....
, something wasn't right as he mentioned ! I finally found out why my pv arm had a so small range of movement , the problem was in the upper arm, the one with the ball joint in it.
) , this is the result:
