125-200cc 125 clutch parts reassembly order?
dfeckel
Alright, I'm an idiot.
I took the clutch out of my 08 CR125 to send to EFM, and in the several weeks between disassembly and reassembly, I've forgotten where the needle bearing goes. Can someone please list the order of reassembly starting with a bear trans input shaft? Or post up the parts diagram? Thanks!
The needle bearing goes in the sleve in the clutch basket.
It's the big washers you need to get right.
Take a look at Halls cycles....they have the the parts PDF on their site.
Where are you in NJ? I'm in Dumont.
Also you have two needle bearings and a spacer that go on the shaft and you need to get the spacer inbetween the bearings. As R Little said go to the parts break out and it will show you the order.
Walt
tommie d;72242 said:
You can get PDF of the parts and owners manual here.
http://www.husqvarnaracingclub.cz/ohqv_manualy.html
That is the best (in my opinion) way of assy, using the exploded parts catalog goes a long way. I have used this technique for many bike projects and am using it now for a 94 KX125 basket case that is going back together, plus if by chance you are missing parts you can instantly order them by P/N from the dealer.
also Hall's husky has them too
