Fooschnickenz
Bikes been good to me, I ride almost an hour a day. Yesterday after riding I let it cool down a bit and hosed it off, afterwards it was a lil funky in the low Rpms almost like how it was pre 12 port injector and ecu. I chalked it up to coil stick getting wet as it cleared up in a few minutes of riding. Today when I turned the key on the fuel pump primed but sounded a little off. Bike road pretty good but as I got closer to home and bike got nice and hot it had the slightest off idle bog but was fine above that. Got in the garage and noticed it was banging into first again so I lowered idle a bit down to around 1900-2000 and was testing it still clunked. Then the fuel pump locked up on me for the 2nd time cause of the heat. Waited a few min it started up but fuel pump sounded labored again, while running it still clunked into first and I noticed in neutral with clutch out it made kinda a banging sound. So my questions are
1. Is my fuel pump shot, if yes where do I get a new one and should I add some kinda heat reflector under tank
2. Any input on clutch noise, I assume it's connected to the first gear clunk(also from neutral to 2nd)
3. Is this what the zippy clutch bushings address?
Bike has 1350 miles and about 60 hours. First 1200 miles were put on in 35 hours with previous owner.
