'09 TE510 suspension question
moreccsthanlbs
i have an 09 te510, i need to get stiffer springs...do i need a revalve also? my other bike being an "mx" bike(kx500) got a revalve with new springs....but the te being an enduro, would it be neccessary? thanx in advance.
Depends on your weight and what your using it for. Are you getting new springs for the front, rear or both? The rear has good valving and you might be able to tweak it with your new springs. The front I think is under valved and could prove to be worse with stiffer springs. Either way, springs need to come first, then see if you can get them dialed in with your stock valving. If not a revalve might be in your future.
i'm 80% desert, 20% single track...with my weight (300) i know i need the stiffest springs....but hopefully being an enduro, it will already be valved for off-road.
