Purple Haze
I ran the Delaware State Enduro last weekend and about a quarter of the way through it my clutch wouldn't disengage . I was unable to timely get to my reservoir cover as bark busters interfered with rotating it upwards so I finished by removing two clutch springs . Found on here that the piston was a common cause of it and ordered one through one of the C H sponsors . As I disassembled the slave cylinder this what I had found ( see attached pics ) ,the snap ring was off and setting against the case bearing . The edge of the slave cylinder was missing enough of the edge to allow the snap ring to come off . I didn't touch the clutch lever during any of the removal process . I 'm just curious if anyone else had this issue or what some others may think what caused this .
