09 TE310 Frame Rubbing Issues (Chain)
T300
Chain rubbing frame on an 09 TE310. Mine seems to be doing that. None of the chain sliders/guides are worn, the bike only has 12hrs on the clock. Is this common?
What's the fix?
I have turned my chain link to the inside (the circlip is next to the spokes. That helps a bit. Other than that it is a very minor but regular occurance.
What's the fix?
the chain buffer was changed in 2010..it has a guard molded onto it that keeps the chain away from the frame..its cheap, it bolts right on and it works. i changed both of ours.
You can try running a DID520VT2 Chain.
These are about the most narrow o-ring chain you can get. I noticed a improvement after changing to one.
