09 te 450 turn signals not working ****************************************!
motoxned
Anyone ever have any problem with their turn signals not working ? Mine just quit ! is there a fuse for the signals, ??? all the connectors are tight, but there is no juice to any signal ?????
Check all the fuses? Also the relay, and switch. insure you have power. also, bike must be running remember...
The flasher indicator on the dash works but the signals wont blink ! How can i check the flasher relay ??
Under the seat on the right hand side of the bike are 3 fuses. I think one of them is for the blinkers. Replace them all, mine worked for a month then broke, but looking at them they looked good.
12V test light to check relay. Does the indicator on the dash flash or stay solid? Also, Bulbs may be a factor in a small bike system. Autos flash faster when a bulb is out.
The tiny OEM flasher relays seem to fail frequently. I had them fry on two different Huskys. Replace with a non-OEM relay from the LBS of your choice and you're good to go :thumbsup:
