09 SM510R DRC Edge Tail light Installed
Brrrrp
Here are some images of the DRC Edge 2 Tail Light installed on my 09 Sm510R...
I didn't even ride the bike until I removed that ugly stock setup....
I got the light with the 12oclocklabs board so i don't have to have separate turn signals.... I'll post video of it working if anyone wants?
If anyone is going to do a tail light mod here is the wiring colors:
Red/Black = Right Signal
Sky Blue = Left Signal
Blue = Ground
Green = Brake
Yellow = Running light + Plate Light
I used a 5 Circuit Molex connector and I soldered and heat shrank the wires... (must nicer than factory connectors)
I had to narrow the DRC bracket a little bit to fit up higher on the fender. I also cut the stock bracket and welded in a bar that flowed with the contour of the fender... (I wanted it as flush as possible)
Looks good.....where in SoCal are you located? Do mind helping me do this to my 510? I'm located in Menifee, Ca.
Nice work. Why did you bought the 12oclocklabs board? Won't the original indicators work without it anymore?
Sorry i'm not a native english speaker. Thanks for your help:thumbsup:
