08 te510 starting problems ???
jonny08te510
Running awesome for months then after riding oneday went to start her next day the fuel pump didnt prime ??? I checked fuses which are all fine , voltage is normal, checked as much of the wires I could etc.If it is just a fuel pump failure should the elec start still crank ?when I turn the key no fuel pump sound the headlight comes on and only the headlight light not neutral light comes on.Im bit puzzled as bike was fine day before been awesome since I got it I removed the fuel pump assembly but how do I test if the pumps faulty ? And why does the elec start crank at all ?
E start should and will crank at all times, whether fuel or air or compression are working or not, the starter should crank.
Just use some wires with alligator clips and connect the fuel pump (de-installed from the tank) to the battery, it should whir up and throw some gasoline out.
You will probably find that the pump works fine and that you will need to start looking for a bare or loose wire.
Thx so it's prob not the fuel pump at all the fact it isn't priming is done to elec fault somewhere that why the estart isn't cranking?
