08 te510 random cutout, no power to dash, won't start!?
James0604
Hi all new member so forgive me if I've posted in the wrong section or anything.
I have an 08 husky te510 fuel injected.
Last weekend on a fire trail ride my bike randomly cutout loosening all power to every part of the bike. I was stranded and there was no way of kick start it due to it being fuel injected and needs power.
Battery is 3 weeks old and is fully charged. No loose plugs or wires. Fuses are fine.
The only way I can seem to get any power from the bike is if I hold the electric start button in then try and kick the bike over. The dash then powers up but still won't fire. Random codes such as a888 an 35e4 Appear for a split second, ( happens quick, but I'm pretty sure there the codes that come up).
But as soon as I let go of electric start button, all power is lost again.
There was no signs of a problem before that bike was running great, the day before it did blow the yellow 20a fuse which is the one for the dash,lights, blinkers. But once replaced bike was fine again.
Any input or info would be great thanks.
Sounds like you have a wire rubbed bare somewhere.
definitely frustrating-
The Ignition switch (RED) needing to be held in manually like you said- sounds like an area to focus on (verify the pump primes when you are holding it in). It controls the ignition circuit (after the key'd switch is on)). The starter switch (black) turns on power to the starter relay-to turn power to the starter. The key'd Switch is a double pole- that turns on the DC circuit (tail light/ euro mini headlight) and the ignition circuit (starter relay/ pump relay).
Test that switch and follow those wires. Could have some intermittent shorts as suggested. good luck
The pump isn't priming.. Due to it needing power to fuel injection,
I have looked over every wire today and there isn't one damaged looking wire. So unless it something internal or a wire I can't see..
Might need to go to an auto electrician, as I don't really no how to test electricals.
The codes that come up on the dash is there anyway to find out what they mean? Are they fault codes?
Check the battery ground wire and the positive battery wire.
Try the old battery again.
I bought a new battery for another bike and it was bad ...........created all sorts of problems........including burning one of the charging wires from the inside out.........but the bike would run once bump started.
I have tried the old battery in my mates bike works fine also tested it.
We're exactly does the the ground wires run to?
Could they have rubbed bare under the insulation in the main harness?
Once you find what wire or connection is shorting out, go over your bike with the plastics and fuel tank off. Dielectric grease on your connectors, zip Ty connectors in place, RTV silicone on wires where they rub, possibly rub. Husqvarna didn't think about some of these little things that turn into big things.
