08 TE 510 Low end throttle response
BrandonB71
I ride some pretty technical trails, very rocky and sometimes very slow.. Ive done everything I can with gearing but still am a little disappointing with the smoothness of the off to on throttle response.. Just seems a bit too choppy.
Any Ideas on smoothing her out a little.
@ older huskey rider.. No Honestly this is the first EFI bike Ive ever had..I was hoping to avoid mapping.
@ Radar... Great Idea.. Giving that one a try
Good luck with that, depending on the state of the bike (stock, PowerUp done, or partially done, re-map done or not done with PowerUp, your elevation and riding style), you will fight an uphill battle trying to get it to run right without a mapping tuner.
The Jimmy twister looks interesting. I removed my stock throttle tube and cleaned the inside and the handlebar very well before applying a light coat of synthetic grease. You can also lightly grease both ends of the cables, at the throttle and the throttle body. Made my throttle nice and smooth.
But I don't think that either of those mods is going to help you with the low end response you are looking for. More fuel at low rpm's is going to be your only option. Although, you do not have to remap your TE510 to add fuel. You can install a simple JD tuner and add fuel lower in the rpm range.
http://www.jdjetting.com/xcart/product.php?productid=147&cat=22&page=1
Appreciate all the good feedback. Yes its low end throttle response from off throttle to just a bit... Its the lurch at low speeds over rocks thats killing me. Id much rather think about tire placement and balance.
Ill read up, apply apply and report.
I have a 2009 TE510
its being converted to SM for dual use
The bike is powered up and the can de-corked
It has a flat spot first 1/8 th throttle
To overcome this I have purchased a jd tuner as well as a g2 throttle
After extensive reading of others that have had same issues I believe the jd tuner will overcome the problem
+1 with Radars suggestion on the G2 throttle, makes a huge difference to the on/off throttle transition on the larger capacity engines.
Start with the 400 cam for maximum control.
Dave
