Puckerbush
These are the 48mm type with dampening screws on top and bottom. I want to change out the seals and wipers. Is it necessary to remove the lower fork assembly to change the oil seals? From the YouTube video that someone posted, it looks like all that is necessary is to remove the top fork cap, guide spring cap, spring, adjustment return inter rod, drain old oil, slide-hammer the slider assembly, replace seal and wiper with proper slide action tool, add oil, and reinstall fork.
Also, the shop manual for a TE says 725cc or 24.5 oz of 5w oil in each leg. Seems like a lot of oil.
Comments/Advise?
Comments/Advise?
