'07 Te250 Gearing
Ron West
I've got stock gearing and I'd like to make the bike a bit more "street friendly". I ride about 30 miles on street to get to the trails. I don't need to go over 50 mph, but I would like to lower the rpm's without giving up too much. I'm mostly on fire roads for dirt too, nothing too tight.
going 14/50 looks like it only drops the rpms by about 572 in 6th gear. Does that really make that much of a cruising difference? Maybe a 14/48?
Thanks!
Ron
You can probably get away with a 15-50 combo for what you're doing. Maybe carry a 13 or 14 with you in case you get into a tight spot & it's a fairly quick change trailside & no need to swap chain lengths.
That'll drop your 6th gear cruising RPM by about 1000. I suggest using about 6-6500 as your cruising speed target RPM. 7-7500 for short bursts here and there.
Ok, thanks. I was worried about the crusing rpm. This is my first dual sport. So, 6-6500 is not too bad for the engine I'm assuming.
Ron
