'07 TE 250, Greasing the dog bones
MotocycleWriter
I've always called them dog bones. The rear shock linkage. I notice my Husky has Zerk fittings! What kind of grease works well in there? I was just going to load up my grease gun with Belray Waterproof and crank away.
there's one pivot point that doesn't have a grease nipple, it wouldn't last long as you climb over logs etc. anyway but to grease that link properly you need to pull it apart.
it's worth doing, when i bought my 07 i did and found the bearing rollers mostly non existent, replaced and greased it's been fine since but i still anually grease it.
Will do! I pulled apart the dogbones on my 2000 Montesa Cota 315R and pretty much poured out iron oxide powder! Sure rode smoother after I replaced the bearings. I'm guessing All-Balls if I need anything? Thanks for the responses. Been out of town making it hard to reply.
