STmatt
My 450 has a Rekluse and up until a few rides ago I could also use my hydraulic clutch. Then I lost all pressure in the lever, but could still ride. But I have a hard time finding neutral while the bike is running and it seems more difficult to start. So I pulled the clutch slave assembly and found the wall of the assembly that fits into the motor was slightly chipped and the o-ring was broken. I bought another clutch slave assembly, installed it, bled the system, rode it around the neighborhood, bled it, and thought I was now a Husky mechanic.
I took it up to Georgetown last Friday, roll it off the truck and notice a lot of hydraulic resistance. I try starting the bike and it really doesn't want to start. I pull in the clutch lever and now no resistance at all. I should have loaded it back up but I have two KTMs and a 450x waiting for me. I get the bike started and ran it hard, didn't shut if off except for a fall in some rocky waterfall area, and the bike is running hotter than I've ever seen it. I get it home and pull off the new clutch assembly and found almost the exact same problem again. Broken o-ring and a badly chipped housing.
My Ktm buddy thinks something is going on with the Rekluse/clutch plates..........any suggestions, answers, similar problems? I now need, at the very least, a new o-ring, I might be able to salvage my old slave cylinder housing.
Thanks Matt
My Ktm buddy thinks something is going on with the Rekluse/clutch plates..........any suggestions, answers, similar problems? I now need, at the very least, a new o-ring, I might be able to salvage my old slave cylinder housing.Thanks Matt
