00 610 sm jetting advice wanted.
johnclearysm610
I have a 00 610sm e start. I put two straight through tailpipes on it and trying to get the jetting right to suit. There is a surge/stutter when trying to hold a steady speed on low throttle and getting some loud popping on decel. I have changed the main jet to 185 which has helped a little with the popping. The carb is a dellorto and is currently running
Jet sizes:
Main= 180 changed to 185
Idle = 50
Start= 50
Atomiser= ab 260
Venturi valve= 300
Needle= k32
Fuel screw=2 turns out
Any advice will be much appreciated, thanks.
I saved myself a lot of trouble here in SA --Imported some JD Jetting kits for my 610 SM --450 TE AND 510 TE
End of all the things that bothered me with low down bogging etc --smooth and crisp --all the way -was money well spent
The needle was the biggest factor I found ---
