00 610 oil pump
johnclearysm610
Had my RH cover off and checked clutch plates etc. I took the oil pump that's in the cover apart to check it and there is a small hole in the bottom corner of it, it looks like a piece has broken out. Where can I get a new one?
I'll take a pic this evening. I contacted my local husky place and husky sport. Neither have the complete pump in stock and because the parts place is being moved from Italy to Austria it will be 12th May before anything can be ordered. :-(
It's all small peppered holes, one large on the inside and one large on the outside. Do you think is it scrap? I'm just worried it will affect oil pressure.
I don't know enough about it to respond intelligently, but I don't think I'd use it. Seems strange to be coming apart as it seems to be. Now that's a pretty simple part, so if cost and delay of procurement is too much to stomach I'd take it to a machine shop and ask them to replicate one for you. They'll use a micrometer and make a perfect reproduction of it in the right material. Now of course a lot depends on your local machinist- some do these things quite cheaply and others not so cheaply. That part (if it's as simple as it looks in the pic) should be fairly simple and inexpensive.
The first whole is on the outlet ?
do not mind second whole, but if already created two holes already I recommend replace this element, material from another whole could cause damage in engine and indeed cause a decrease in oil pressure, and then cost will be large.
I have no access to a lathe or if be making so much stuff for myself. A broken up rotor magnet is what caused the holes. I think I have most it cleaned out so there shouldn't be anything to make anymore holes.
Is that steel or aluminum? Are the holes through or blind? I'm not familiar with how those pumps work, can you take a few pictures showing how it goes together? It's hard to tell if that would effect it at all.
You don't have a location shown, where are you? If you're close to me, I'd offer to take a look at repairing it.
image.jpg inner most side. image.jpg outer most side. image.jpg assuming one of these last two pics that one hole
Is oil in and the other is oil out. image.jpg they are blind. More like chips rather than holes. I live in Ireland. Must put up my location. Thanks for the offer it's much appreciated. I not sure if it's steel or alloy. Feels kinda light to be steel though. Does this help? It's about £50 for just the housing part that holds the two impellers. Thanks.
Yeah, I was hoping I could figure out all the details from looking at the pictures, but I think I'd need one in my hands to be sure. Sorry!
I'm not convinced that those pits are of any consequence, but I don't want to have you trash a motor without being 100% sure, so I don't want to make any recommendations.
Thanks. I don't think they would either but not willing to chance it. Husky sport had one in stock the other day. Hope it's still there.
