All 2st Zip TY air screw... problems
krieg
I thought long and hard about posting this. But now that I've experienced the same issue on two bikes, I had to tell the story.
I installed a Zip Ty air screw on my 2011 CR 150 this past Spring (April/May?). After installing the screw, I began to experience erratic idle issues. At the time, I thought this was due to a bunch of other jetting changes I made at the same time. Since then, I was never really able to achieve a stable idle setting on the CR, but I kept the ZT screw in because I thought the problem was related to float level and other jetting issues.
Yesterday, I installed another ZT air screw in my 2012 CR 125. I immediately noticed difficulty in achieving a stable idle. I futzed with the screw and the idle for about an hour and could never get a stable idle setting. I put the original screw back in at the original setting, adjusted the idle screw to the original setting and all was wonderful again.
Then I yanked the ZT screw on the 2011 CR and put the OEM screw back in... after a few tweaks, BINGO, stable idle.
Not sure what is going on here... but the results I've posted are real. After examining the ZT screw and the OEM, it looks like there is a substantial difference in the tip. The ZT screw tapers down to a flat. The OEM screw tapers down to a rounded end.
Nice to know. Too bad it doesn't work, as a quick no tool adjustment, for the air screw on a small bore would seem idea.
You may want to try rounding off the end of the zip-Ty screw to match the oem and see what happens.
+1 for the RB Designs screw. The RB Designs screw is machined brass (like OEM) and it's profile is be controlled better. It also has a tension spring to preload the screw threads. The aluminum screws tend to be like you described and more conical shape. Also, the aluminum threads are sometimes more sloppy fit. Both can lead to less precise metering of the air passage.
On my old SM610 with FCR carb, I noticed the same issue on the aftermarket fuel screws. The aluminum ones were junk. The brass ones from Scott or Merge Racing had a nice sharp tip like the OEM screw.
Will this wor with the pwk (keihin)
another RB user here... quality stuff, but I think it is only available with carb work?...
He makes a screw for the Mikuni?
