Two Keys? Maybe not.......
Discussion in '610/630' started by Nesbocaj, May 1, 2009.
  1. Nesbocaj Husqvarna
    I felt that having a separate key for the gas cap was dopey, so I took that sucker apart:
    If you look at the top green part on the backside you'll see a locking pin. Depress the whole deal and the pin falls out.
    Remove the spring and the second green piece
    Pry up the last green piece. You can remove the rubber seal if you want.
    http://i143.photobucket.com/albums/r155/nesbocaj/GasCap/IMG_2178.jpg
    The lock mechanism will now just push out to the front
    Leaving the O-Ring in the cap, it goes here
    Next loose the tabs that hold the pretty cap in place, and remove it
    The lock pins will stay in place till you remove this brass pin
    from here:
    If you tap the lock on its face the brass pin will start to fall out.
    THIS IS THE POINT WHERE you should ask yourself if you want to proceed.
    Pins out, their springs next to be removed, these will STAY out.
    I modified (drilled the crap out) of the lock so that the stock key will fit in comfortably
    Filings cleaned out, RED key slot thing put back in place
    Put the cap back on, bend the tabs back to hold it on, greased the lock, O-ring back in place
    Insert the lock back into the cap.
    Refit the rubber seal
    Refit the bottom Green piece
    Refit the second Green piece
    Insert spring
    Place top Green piece in place, line it up with the rod hole in the lock mechanism, and the two Green pieces.
    Compress with a vise type tool
    Refit the locking rod
    Notes: The brass rod no longer holds anything, leave it out if you want.
    IF you find that the mechanism won't turn, disassemble and rotate the lock 180° and try again.
    ANY key/thing that fits will now unlock the cap, BUT, it looks stock, and looks like it needs a key to open.
    What I wanted to accomplish:
    My ignition key now fits the gas cap lock, it turns it to lock and unlock.
    WHY: It was raining and I had to be home for something else. :excuseme:
    TIME: 1 hour 15 minutes.
    Muddy Waters likes this.
  2. WoodsChick Administrator
    Oakland, CA Miramonte, CA
    KTM, GasGas, Suzuki, Honda
    Bravo!! :applause:
    I am going to read this thread again when I haven't been drinking red wine and we will probably be doing this very thing to my 610!
    BTW, Eric's LC4 has the exact same gas cap and his works with his ignition key :mad:
    TipsyChick
  3. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    Thanks for posting.
    I'm wondering with the lock pins exposed, would it be possible to stick the ignition key in and then grind the misaligned pins to the same length. This would be like re-keying the tumbler for the ignition key. Just a thought for allowing it to be lockable.
    Of course, if that fails then you would just remove the pins like you did and make it non-lockable.
  4. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Most Excellent. :thumbsup:
    Thanx for sharing.....
  5. Nesbocaj Husqvarna
    I was going to go that route, till I looked at the keys. Different
    shapes:banghead:
  6. Wetdog Husqvarna
    Tsawwassen, BC
    Better pass the bottle around to Nesbocaj. It definitely can't impair his closeup photgraphy, in fact I think a drink might settle him down.
    Great info Nesbocaj. :thumbsup:
  7. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    :lol::lol::lol:
    If you scan through the picture quickly the get blurrier with each one.:lol::lol:
    I think he was into the wine.:D
  8. Nesbocaj Husqvarna
    :cheers: Corona. But I did get it back together :D
    If you print out the pics and staple them together and then fan them quickly with your finger, they will be just as blurry.:lol:
  9. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    I was looking at my bike today and a thought occurred to me...
    How about using the core from the helmet lock and install it in the gas cap?
    The helmet lock uses the same key as the ignition. :applause:
    Well, I took off the helmet lock but could not see how to disassemble it easily. Anyone know how to?
    The length of the core would be too short compared to the gas cap version shown above. However, you could possibly replace the key pins in the gas cap with those in the helmet lock.
    Just an idea... :excuseme:
  10. Nesbocaj Husqvarna
    Good idea, but no go. The cap tumbler is built as one piece, not as a lock insert. See blurry pic #5
  11. MattR 2T Forum Clerk
    Temperance, MI
    WB165, SM610
    Yamaha FZ1
    http://i143.photobucket.com/albums/r155/nesbocaj/GasCap/IMG_2175.jpg
    I was thinking more like this pic, where you would swap out the key pin & springs for those with helmet lock's. Basically, reassemble using only pins for the ignition key. It's an idea but may not be possible. :excuseme:
  12. Nesbocaj Husqvarna
    I looked at it closely before removing the pins. The keys are two
    different shapes, one will not fit in the other. Try to fit the gas cap
    key into your helmet lock, you will see what I saw.:D
  13. AveryCloseCall Husqvarna
    San Francisco
    2007 SM 610
    All the photobucket hosted images are gone. Anyone have copies?
  14. ZX10R203 Husqvarna
    California
    2006 SM610
    2005 Ninja ZX10R, 2009 Raptor 700R
    Sorry to raise this from the dead but does anyone have this write up with pictures???
