Tuning a CR500 for higher rpm
Discussion in 'Vintage/Left Kickers' started by Nikel, Oct 26, 2014.
  1. Nikel Husqvarna
    Husqvarna CR500 1987 Supermotard.
    Kawasaki Zx6R 1997
    Hello.
    Anyone here tried to get some more rpm out of the L/C CR500.
    When riding on the street the maximum 6500RPM is a bit low.
    The cylinder has high duration times so the pipe is the issue.
    Is there any aftermarket pipes I can buy?
    Kind Regards
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    my brother had a 1986 500 that had been ported and had an Up-Tite pipe on it
    it definitely ran a higher RPM but never really checked the difference except that it would stretch your arms and slide you pants as you slid back on the seat :eek:
    not sure who ported it but he bought it from a desert racer back in the day
    it was fast!!
    actually too fast for anything but the open desert
  3. 2premo Husqvarna
    Northern NV
    are you running a 40mm carb or a 38
    is your timing at 2.2 or retarded to 1.9mm BTDC
  4. Nikel Husqvarna
    Kawasaki Zx6R 1997
    i'm running a PWK 39, but didn't notice any difference in the rpm when i changed from the VM40.
    I couldn't fit my caliper to measure but the SEM is at 15 degrees at TDC.
  5. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    the 82 cr500 was max hp at 7k according to the magazine dyno . has a graph etc .intersting that peak torque and hp are within 1000 rpm of each other .
    but then i see in the "slavens ported 500" thread someone claims the maths on the porting adds up to max power at 9k
  6. Nikel Husqvarna
    Kawasaki Zx6R 1997
    That's my calculations.
    My tuner friend told me that the cylinder is tuned like snowmobiles 2-strokes.
    They have high port durations and the power is adjusted with the exhaust.
  7. silverstreakNZ Husqvarna
    Christchurch nz
    cool . yeah i wasnt trying to imply what u were saying was incorrect or Gospel .
    what do the other big bore 2 strokes rev out too ? is it realistic for something as under square as the husky 500 to stay together and/or make good power at 9k ?
  8. Nikel Husqvarna
    Kawasaki Zx6R 1997
    No problem =)
    It would probably last a race or two.
    Honda Cr500 revs 9000 if you want.
    But they have 89 bore and shorter stroke.
  9. Nikel Husqvarna
    Kawasaki Zx6R 1997
    Anyone here tried the Dynoport pipes?
    Is there any other manufacturer who makes pipes to the late 500
  10. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    different application, but im very happy with the dynoport system on my 360. fits great and is very well made. when i buy a pipe for a swede they would be first choice. the bike pulls better everywhere, which i have heard is their specialty. im sure if you were after higher rpm they would alter a pipe for you upon order. i also run the big core spark arrestor and it has a nice growl and deep tone without being overly loud. Photo383.jpg
    juicypips likes this.
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    The gnarly on my 360 is better throughout rev range and half the price of dynoport by the time it would have gotten to me, humm big bore 2 stroke i need one cr 500... I want one
  12. justintendo klotz super techniplate junkie
    most of their mufflers kinda look the same, i think mine is basically their big core barker cut down with the spark arrestor section welded on. all nice dirt bike grade tigwork Photo384.jpg
  13. justintendo klotz super techniplate junkie
    have you been able to compare them?
    would be nice if pro circuit made pipes for swedes that were still available. dp still has them for all lc huskies up to early 2000s
  14. Martint93 Husqvarna
    Flekkefjord, Norway
    1987 Husky WR400, 1985 Husky CR500
    KTM 200, 300, 380, 525
    Hi Nikel!
    what about try the easy way? try shorten the header an inch or two ;):)
    I ran a modified wr400 pipe on my lc500 at first. lost som bottom end and midrange, but sure as hell pulled higher rpm's!
    I am now running a stock 500 pipe and has a lot more midrange but I miss the high revs! :(
    with the 400 pipe it would do 150km/t in 5th gear, now with the 500 pipe it only does like 150km/t in 6th... so the rpm is redused for sure!
    -Martin
  15. Bigbill Husqvarna
    '83 250wr
    0 right now
    Don't forget the option of a larger front sprocket. With the extra torque and horsepower we can add a larger tooth front sprocket and take back some rpm and add more speed while lowering the rpm.
  16. Martint93 Husqvarna
    Flekkefjord, Norway
    yes, but I think I am at 15/48 already...
  17. Nikel Husqvarna
    Kawasaki Zx6R 1997
    Hi everyone.
    I have thought about shortening the stock pipe and I have calculated my own pipes to.
    But it's not the easiest jobb to make it fit nice.
    I have spoken to Rich at Dynoport and he can custom made a pipe for mid and high revs like he do on the Cr Honda.
    $695.
    Expensive but I guess it worth it.
    Maybe I would see if the 400 pipe is easy to get hold of..
    Bigbill I am already running with a 16 front sprocket and a 48 in the rear.
    Not much to do there.
  18. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Nope i couldnt justify two expansion chambers, i ment the gnarly has more everywhere over the stock specs pipe.
  19. Nikel Husqvarna
    Kawasaki Zx6R 1997
    I have emailed a Swedish company about the pipe.
    Well see what they say about my ideas.
  20. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    Have you thought of trying a pipe from a more modern open class bike , that is what I had on the 1962 Greeves MDS I used to race, an early Husky Evo pipe in fact, worked 100%. Much easier to cut and shut than build a new one. You must be very brave to want a Cr500 to go even faster!
