Thought I'd start a fresh thread for this subject as I'm sure it will expand. I want to put a Vapor on my 06 WR 250. I've used the part finder on the TT site, but have a couple of questions. 1. Is the 752-102 the best option or is there one that includes the optional temp sensor that doesn't require a hose cut? Which is more accurate in terms of coolant temp? 2. I'm not running lights and as a result not using the voltage regulator. Will I need to install it in order to run the unit/prevent damage? Thanks!
The fin sensor works fine and no need to cut the line. input - 9.0-400 VAC/VDC (No polarity requirements.) call and ask but seems it should work fine.
