Time is coming to rebuild '06 te450
skyrubber
Time to rebuild my '06 te450 is coming.
So I searched this forum to find the sites selling rebuild parts for the bike.
I found a few site for some parts such as piston sets (ebay), decals (also ebay)
But I can't decide where I can purchase valves, con rod, gasket sets,
valve oil seals, etc.
Del west, hall's cycle.... I read lots of posts talking about that.
But there is no parts for 06 Te450.
How can I find the parts for rebuild?
Which site is the best for Husky parts?
I am about to regret to purchase husky instead of KTM. T T
Please rescue me
Take it apart first do a thorough inspection then find what needs replacing, valves,for example, mine were exhaust only bad, intakes cleaned up perfectly. piston and rings for sure, i also did my shift drum, all crank bearings (crank rebuild), new cam chain and guides, new seal kits bottom and top end, cams were good, as were the gearbox and shift forks. tear it down do your assesment then hit up one of the dealers(like Halls), OEM parts are really priced reasonable on these things (they are not cheap for sure, but the quality is high), I also paid the @200bucks for the SM counterbalance shaft assy with drive gears(welded the crank gear) and this was well worth the xtra bucks. updated my water pump with the 10 model higher flow one as well. and a bunch of other little stuff.
My old 2007 510te was rebuilt/top end only at 450hrs. I purchased a Wossner piston and a full gasket kit just in case something else would rear its ugly head. One would think I would need a complete top and bottom end rebuild but the the head was nice and leak free and the crank/con rod had no play. I LOVE HUSKY's.
BTW 06 and 07's are the same
