I got sick of replacing the leaking clutch master cylinder piston on my TE630, so I bought a used master cylinder from a Ducati Monster. Problem is, I didn't realise the Ducati clutch used DOT3 brake fluid while the TE630 uses mineral oil. So will using mineral oil in the Ducati master cylinder be OK, or do I need to use brake fuid, and will this work ok in the 630 slave cylinder? Thanks in advance. Homer
but where did you find a 9,5 mm brembo repair kit? brembo does not sell 9.5 mm clutch pumps ducati does not have 9.5 mm clutch pumps
Yes, but Magura sells them (the 630 uses a Magura master assembly.) Rebuild kits are available from numerous sources.
if you use the DOT 4 for a clutch pump you have to replace the OR2093 23.52 × 1.78 oring with EPDM on the clutch actuator on the crankcase
