TE 610 Fork Bolts
Bunny007
Does anyone know torque specs for the 8 bolts that hold the forks- 4 upper and 4 lower ones? I plan to loosen them to straighten the steering. Manual is unhelpful. I am thinking maybe 15 ft-lb or so. Thanks.
The top four I go 18 ft lbs and the bottom four 12 ft lbs or a little more. The main theing is not to overtighten the lower four, cuz it can cause sticktion.
Yeah, this is very important as apart from the stiction it also wears the insides of the tubes. Another thing to bear in mind is that as the bolts work in pairs, so slackening one will increase the torque on the other. This means if the first bolt is loosened completely the second bolt can strip the yoke thread as it's wound out, so slacken each bolt a bit at a time. Remember, it's always possible that a_previous_owner has tightened 'em to busting point! :)
