TE 511 /449 starter repair.
9880sts
Picked up bike from Workshop , just to find out, that the starter wont Crank over.
Bike is in Warranty , but dealer was to busy to get going on it. ?!?
Bike got 2600km on the meter.
So i pulled the starter out, which wasn't really as easy as i thought.
You have to remove the Main Water hose from Water pump to Radiators.
then remove the 2 bolts which hold the starter in place. Then lift the starter out between Engine and Frame.
Without removing the Main T Water hose, there is no way or almost no way to get it out without removing the hose.
So i opened the starter and before i did that, i saw the 2 Rubber seals were squeezed out and couldn't properly Seal the unit any more.
As i pulled the end piece of , dirt and black crap came out of it. The Spoole was rusted and the Brushes were stuck in the Slide.
The Bike would only start with a tap on the starter..
I cleaned up Spool and Contact Surface with Scotch Brite. Cleaned inside aswel with Scotch brite.
Removed the two brushes and got them nice free moving again in the slides.starter1.jpgstarter2.jpgstarter3.jpgstarter4.jpg
The Genuine Rubber seals damaged and stretched, i needed s solution. I figured i take a 30mm diameter Oring and istall this one instead.
When you look at pictures, the O-ring Seals perfect. The starter itself is easy to open and Maintain.
So i installed it back on to the bike and all good.
Nice one. I might open mine up & give it a tidy up.
It's been underwater a few times crossing creeks...
Your repair might save a few guys a dollar or two as well!
yes I noticed mine the other day and since have now put silicon around the outer seals. see how that travels.
