Hi All I am having difficulty locating spare bolts that fasten the shrouds to the tank. The bolts ( as per the sample in the picture below ) are really a combined bolt and bush. Does anybody know the part number of these bolts or where I can source them. ? I have tried www.ShoptItalHusky.com (formerly HuskyParts.com) and Husqvarna but no luck. The problem is that the Husqvarna Parts List (as per the picture below) and the SVM Motorcycles Parts List ( the SVM RS300 R and RS500 R use the identical bolts on their tank shrouds ) both show the part as a separate bolt and bush, i.e. two part numbers. Husqvarna is unable to supply these two part numbers and I think the reason is that in reality they don't exist because in reality there is only one combined part which does not appear on the parts list
The bolts will depend on the year and model, some are shouldered bolts and some have the bushing separate. Also husky used 5mm and 6mm bolts depending on year and model.
Looks like from 2010 at least it was all shouldered bolts as was on my 510 and 630's. Even SWM uses shouldered bolts. But all parts lists show bolt + bushing.
https://evolutionbike.it/swmstore/oem-parts/rs-sm-650r/frame/023-gas-tank-panel.html SWM dealer has them in stock. Looks like part # 8000A8421 I have ordered parts from them in the past. Super fast delivery.
Willie, you have outdone yourself here my man. Thanks very much for this, I will order some from them.
