Yesterday during a cleaning and greasing of the swingarm i noticed that the swingarm has an axial clearance at the end on the wheel pin of 3,4 millimeter.... This is normal? I also see that the HK2216V bearing has 37 needles. It seems that you miss it 1 :-(
Not sure but seems a tad wide to me. Have a look after you reassemble to correct torque numbers. It should snug up at that time. You do need some leeway/tolerance to work on them. let us know how you get on. Ciao Ciao
That bearing is missing a needle roller (and grease). If that is the shock bearing there should be some axial movement to allow for self aligning.
is there anyone here with a HK2216V bearing to see if the needles are 37 or 38? thanks for collaboration
being in doubt I have re-established the entire leverage system. inside there are 4 HK2216V. The needles for these bearings are 37. it is impossible to insert 38. the space remaining between the needles serves to lubricate the same needles with the grease. Some photos
