swing arm bushings for 76 250 WR
I'm looking for replacements for the swing arm bushings on my 76 250 WR. Part number 15 10 367-01. What have you guys used for replacements? Has anyone tried the bike buzzard bronze replacement kit? http://www.ebay.com/itm/HUSQVARNA-1...hing-Bronze-Replacement-KIT-NEW-/150950967718.
Thanks!!!
Are you wanting to do away with the rubber bushings? If so, what I do is ream the swing arm pivot bore out to 26mm and install the oem type needle bearings and spacer sleeves and O rings like husky started using in 1977. Just my 2 cents worth.
Marty
I've turned my own phozy bronze bushes to try for the coming season. Will see how it goes.
Thanks guys for the responses. They both sound like good ideas. I'm hoping to save the ones in the swing arm now but the wear washers were missing when I bought the bike and there is some slight damage to the bushing as a result. It's good to have a couple of options available.
Thanks again
Mark
