This is actually the method I was attempting with a T spinner although not too aggressively because I didn't want to do any permanent damage.Get ahold of a 1/4" drive electric impact or air impact wrench (you can do it with your hand socket wrench but it's easier with a power wrench). While turning the bolt (and spun out captured nut), use a wide thin blade like a screwdriver, stiff putty knife, or thin chisel to pry the bolt and captured nut out of the cavity at a slight angle. You can then remove the bolt from the captured nut.
Spinning at high speed makes the plastic warm, warm plastic is more pliable so less prying with the screwdriver, if you get it hot enough, it pops out pretty easy. looks like JonXX did the same thing, his top photo looks like how mine turned out. I was kind of nervous about this too at first.This is actually the method I was attempting with a T spinner although not too aggressively because I didn't want to do any permanent damage.
yeah, like making a hole in the tank kind of nervous!Spinning at high speed makes the plastic warm, warm plastic is more pliable so less prying with the screwdriver, if you get it hot enough, it pops out pretty easy. looks like JonXX did the same thing, his top photo looks like how mine turned out. I was kind of nervous about this too at first.
yeah, like making a hole in the tank kind of nervous!![]()
